Hydraulic lift
Rusty Shows
03-24-2003 11:52:47
My Ford 3000 diesel lift will not hold position, it will either raise all the way up or go all the way down. What can my problem be?
Gary-Miss
03-24-2003 16:11:40
 Re: hydraulic lift in reply to Rusty Shows , 03-24-2003 11:52:47
Check your draft control lever first (the ittle lever next to the lift lever) It should be in the vertical position for position control. The horizontal position is the draft position and the lift lever must be within two inches of the end of its travel before the lift will move. If it is normally used in the position control position and it gets moved to the draft [position, quite often they will stick. Sometimes you can keep playing with them . Other times, the lid must come off.
