you bought an excellent tractor.. a common ford FL1 or pram PH8a will fit this model for oil changes.. use a diesel rated oil designed to handle the problem of soot that only diesel engines have. these diesel rated oils also have special additives to counter act the high acid that diesel oils get due to the sulpher in the diesel mixing with the mositure. this creates sulferic acid and does further damage to the engine and shortens the life. the worse thing you could do is run a 30w gas oil in you engine. diesel oil standards are currently at "CI-4" so you can find either ch-4 or on the newer products ci-4 specs.. these oils are especially designed to handle the problems of turbo chargers as they will acellerate the oil contanmination. these newer oils are availible at sams, walmart, truckstops, tractor service center under the names of delo 400 15w-40 rotella 15w-40 delvac 15w-40 mystic 20w-50 cat 15w-40 also in 5w-40 in all the above for artic climates at a much higher price. and others.. theses oils are designed for extend oil changes as seen in the trucking industry and are designed to go 10,000 miles between changes and in some cases with the right filters, up to 35,000 miles between changes in exteame heavy duty applications. these are the same oils that cummins, detriot diesel, and cat are now getting a million miles out of their over the road industrial heavy duty engines.. DO NOT RUN gasolene oils in your tractors of any type. the diesel oils meet ALL gas specs and then go on to meet ALL the diesel specs.. the additives will allow safe extend drains while keeping the acids in check.. meaning you can safely change your oil every three years on tractors that dont get run very much. ALL of the owers manuels currently spec this type of diesel oil. especially new holland. sorry, to harp but this is probably the most important thing you can do to make your tractor engine go for 10,000 hours, which is the new bench mark for good tractor engines, gas or diesel.. thiese oils sell for about $6.25 a gallon in most cases, the 5w-40s sell for about $18 a gallon.. do not run anything xx-30 due to higher cam wear. especially on the diesels where extreame cam designs are required to get proper performanced.. good luck bill
