1972 ford backhoe
gerry
03-15-2003 20:43:12
im looking at a 1972 ford backhoe the hoe is removable to use the 3pt. the guy said its a 3500 deisel but i cant find anything on that size. is this correct for that year? also where do i look for the id tag?
williamf
03-17-2003 14:56:15
 Re: 1972 ford backhoe in reply to gerry, 03-15-2003 20:43:12
I think I remember that the ID tag on my 3500D is on the underside of the hood, left side, just rear of the exhaust. Mine has the loader and backhoe models Texadian mentioned below; it's got pegs and holes to mount a three point hitch if the backhoe part was taken off, but it would be a build-the-pyramid scale job for a backyarder.
PS - 38 hp, about 10,000 lbs including backhoe and loader.
Charlie
03-17-2003 06:02:30
Is the tractor a model 3500? I believe that was the industrial version of the Ford 3000 and came with a backhoe and front end loader.
gerry
03-17-2003 06:41:52
 Re: Re: 1972 ford backhoe in reply to Charlie, 03-17-2003 06:02:30
yes its a 3500. it does have the loader and backhoe part. does these two work independent of each other or do you have to shut a valve off to use one or the other?
Texadian
03-17-2003 10:53:34
 Re: Re: Re: 1972 ford backhoe in reply to gerry, 03-17-2003 06:41:52
Gerry, Loader and backhoe hydraulics are plumbed in series. Front mounted pump supplies oil to backhoe hydraulic control valve first; backhoe valve has two return ports, one return to tank, one "pressure beyond" port which supplies pressure oil to loader control valve. No selector valve between loader and backhoe required. If backhoe is removed, hoses mmust be looped to allow continuous flow to loader. Factory loader for 3500 was model 735; backhoe model 753 (13'), bachkhoe models 750 (10') and 755 (15') would also fit.
