Re: 8 volt battery
Mike
03-12-2003 04:35:51
Hey ET,
You've gotten some real good conflicting advice, in over 40 years as a mechanic I can say I've never seen a 6 volt system that was hard to start if it was tuned properly (part of tuning properly is adjusting the carb) with clean solid battery connections. That's not to say it never happens, I just never found one, if you keep everything up to specs you'll find you'll like your tractor a lot more. And have a lot less trouble starting it.
Good luck.
Mike
