134/172 Engine ID
Frank
08-31-2002 14:38:11
Is there a way to tell a 134 gas block from a 172 gas block from the outside? Thanks:Frank
EAF### or EAE###-JimUT nailed it
09-01-2002 03:58:52
 Re: 134/172 Engine ID in reply to Frank, 08-31-2002 14:38:11
See his response to DaveD on what is currently page 2, or follow this link:
DonP
Fred
08-31-2002 18:36:48
If you are just talking blocks, they are the same, different sleeves and maybe a different carb.
snitkawl
09-01-2002 18:03:49
 Re: Re: 134/172 Engine ID in reply to Fred, 08-31-2002 18:36:48
I would sure like to watch someone try to put a set of 172 sleeves in a 134! The bore in a 134 is 3.5 inches. A 172 has a bore of about 3.9 inches. It would take a BIG hammer and a lot of vaseline to get that job done.
Joseph Turrisi
08-31-2002 18:27:24
Look on the engine for an id plate and post the numbers. The plate should be on the left front of the engine when looking from the rear of the engine. Also get the casting number off the right rear side a some one here should be able to tell you what you have. Joseph
