Order Ford 3000 Parts Online
Should I buy a Ford 3000?
M. Wolf
06-21-2000 04:54:42
New to Fords, any advice, years to watch out for....
russ
06-25-2000 18:45:24
 Re: Should I buy a Ford 3000? in reply to M. Wolf, 06-21-2000 04:54:42
bought ford 3000 gas over 20 years ago...with 1450 hours on it..now has 3750 and burns no oil and...tho needing paint job desperately, everything else works and has worked very satisfactorily, well...brakes not best in the world but other stuff is fine...also had to put clutch in right after i bought it, and...it doesnt get babied. very good tractor..
Kermit
06-21-2000 20:07:58
Until very recently I owned a Ford 3000 which was purchased new in 1974. It was a very good and reliable tractor. Mine had a 3 cyl diesel engine, 8 speed tranny, live power, power steering, and differential lock. It was a reliable, faithful friend. Finally sold it to a good friend when I purchased a new tractor. Can't say anything bad about the 3000. May be the best tractor Ford ever built!
Horseman
06-21-2000 10:31:36
I just bought a "61" 841D diesel. It works great!
It has powersteering and a loader. The only advice I have is watch out when buying one with the sos trans.They work awsome when they work but can be exspensive to fix from what i've gatherd by the talk around this forum. I would suggest powersteering especaily if you want a loader. I barrowed a friends 660 with out powerst. and man what a struggle. While discing up some ground on a side hill the front tires would catch a lump a WAM! the steering wheel would crank one way or the other.Watch your thumbs on that! Dont get me wrong on the sos we had one on the dairy and never had a prob. but couldn't tell you how to pick a good one. Just my 2 cents WRP
David Parker
06-21-2000 05:28:26
I bought a 1968 Ford 3000, 3cyl. dzl. two years ago to do some contract bush-hogging. I use the tractor for all sorts of hobby farming also. I have such implements as scrape blade, box scrape, cultivators, "tater" plow and the like. I LOVE MY TRACTOR. The only regret I have is that it doesn't have power steering. I have USED my tractor for the past two years with absolutely no problems. Hope you have as much luck and fun with yours.
Dave
Rick Lees
06-21-2000 09:06:03
 Re: Re: Should I buy a Ford 3000? in reply to David Parker, 06-21-2000 05:28:26
I bought a 5000 ford last year a 1965 It has given me no engine problems or tranny troubles the hydraulics work great I really like it its diesel and the only thing I will tell you is whatever you get find a manual for it it helps in changing filters and regular maintenence GOOD LUCK
