Order Ford 600 Parts Online
Ford 600 Gas Filter
David
06-13-2000 05:15:35
My Ford 600 has a Zenith carb. It runs fine but it has no filter or sediment bowl. What kind of filter , if any, should I install? Thanks
mike
06-13-2000 16:53:22
 Re: Ford 600 Gas Filter in reply to David, 06-13-2000 05:15:35
Get the original line and sediment bowl from N-H. The factory metal fuel line may come with a crimped hose attached to it(not sure if this model has it) that attaches at the fuel valve, this is a special high temperature hose. Make sure the tank is clean and the screen on the fuel valve is clean. Doing any modifications other than original is asking for a problem on these tractors. If you get a lot of sediment in the bowl after installing and your tank looked clean, take the tank off and have it cleaned properly.
Wait! Tommy D.
06-13-2000 11:15:21
If I were you, I'd go to the New Holland Dealer and get original equipment. Your gas line goes between the exhaust and intake manifolds where it gets very HOT and aftermarket or rigged stuff is asking for a fire or explosion!
Just my opinion,
Tommy D.
shawn
06-13-2000 08:34:24
they originally came with a sediment bowl. I added an in-line fuel filter prior to the bowl which seems to be doing a good job pre-filtering prior to the bowl.
Bill Fletcher
06-13-2000 17:08:45
 Re: Re: Ford 600 Gas Filter in reply to shawn, 06-13-2000 08:34:24
I replaced the old carb on my 600 with a new zenith, and purchased the correct sediment bowl assy from my friendly Napa dealer, it even has a fuel shut off on it! The rubber fuel line was replaced and now has metal and no more prblems, this tractor has a 1964 Red Tiger 172 Industrial engine in it, and it is something to drive!! Hope this helps.. Bill
