Ford 2110
Dynocon
06-05-2000 17:28:31
I own a cold natured 1970 2110 3 cyl gas. It usually hits runs for a few moments and stalls only to hit again. After a few start it runs good. Lately it has been getting harder to get it to hit. Currently it will almost start. I pulled all the plugs and the fire looks good and will jump ~1/2".There is plenty of fuel but I'm not shure that it is getting to the chamber. I gave it a shot of staring fluid while cranking with no response. I was ready to buy a tune up kit, but I'm not sure that it would help. Any suggestions?
Larry 8N75381
06-06-2000 10:09:04
 Re: Ford 2110 in reply to Dynocon, 06-05-2000 17:28:31
Check the points first. My 3000 had been the easiest starting engine I own, when suddenly it wouldn't start, just ground round and round. When I checked the points they were SHOT!! Replaced them and all is well again!
Not like a Plymouth slant 6 I had. It would run with a knot on one of the points as big as a pin head. It finally got to running so bad it wouldn't pull it's self up a hill in 3rd, almost didn't make it in 1st. That's when I finally took time to replace the points. :-)
Dynocon
06-06-2000 13:10:19
 Re: Re: Ford 2110 in reply to Larry 8N75381, 06-06-2000 10:09:04
I purchased the tune up kit today. I'll let you know. Thanks for your help
Dynocon
06-06-2000 18:34:06
 Re: Re: Re: Ford 2110 in reply to Dynocon, 06-06-2000 13:10:19
New points,plugs and cond. Runs like a champ. Thanks for you help.
Way to go!! Larry 8N75381 - no txt
06-07-2000 18:06:15
 Re: Re: Re: Re: Ford 2110 in reply to Dynocon, 06-06-2000 18:34:06
no text
