Order Ford 600 Parts Online
600 tractor hydraulics
Sean
04-24-2000 09:28:07
Need help! I bought a 600 tractor and the arms lift only when the control arm is down. The arms lock in place when its in the up position. They move very slowly and will not lift any weight. I had changed the fluid because it had water and dirt in it. I cleaned the system out and rebuilt the pump. It had broken springs in the pump and some gasket debris in the intake line. I replaced the orings on the entire system. I was told it worked fine 2 year ago before it was parked. But you know how that goes. Any suggestions as to why its not working properly? Please help.
Sean
KEVIN
04-24-2000 14:20:40
 Re: 600 tractor hydraulics in reply to Sean, 04-24-2000 09:28:07
SEAN, THIS MAY SEEM BASIC AS YOU SOUND VERY MECHANICAL BUT IT MAY HELP TO TRY OPENING THE FLUID FILL PLUG ON THE HYDROLIC PUMP TO PRIME THE FLUID INTO THE SYSTEM. I HAD REBUILT MY FORD 600 ENGINE AND AFTER RE INSTALLING THE PUMP THIS IS WHAT IT TOOK TO GET IT WORKING AGAIN. JUST A THOUGHT! GOOD LUCK!
Sean
04-24-2000 15:45:22
 Re: Re: 600 tractor hydraulics in reply to KEVIN, 04-24-2000 14:20:40
I tried doing that and it still is not working. I was having that problem before I rebuilt the pump. I was told the broken rings was not putting enough pressure to lift the weight. I took allen nut off and filled up the pump with fluid. Is there another way to do it?
Kevin
04-25-2000 13:13:48
 Re: Re: Re: 600 tractor hydraulics in reply to Sean, 04-24-2000 15:45:22
I am writing to make sure you opened the plug while the tractor is running. I'm sure you did but thought i'd mention it just in case. Other than that, thats all I know. Good luck!
Sean
04-26-2000 11:20:58
 Re: Re: Re: Re: 600 tractor hydraulics in reply to Kevin , 04-25-2000 13:13:48
I opened the plug and I was told to put a hose from the allen nut opening to back to the fill plug to see what kind of flow I was getting. It was moving alot better than before the pump was rebuilt. It had 3 broken springs in it. I guess one of the valves is bad. Thanks for your help.
Sean
Senyah
04-24-2000 20:24:59
Use compressed air to blow into the hydraulic dipstick tube. It will force fluid into the pump. I do not put too much pressure at one time but jst enough to force the fluid up.
Senyah
