Order Ford NAA Parts Online
Re: Rear Seal on NAA
Marc(MO)
02-29-2000 12:24:19
Did you put them in backwards? I just installed a seal in a short block I bought and the taller side of the seal went toward the engine. Make sure that the seal halves are at a 45 degree angle. Also it was easier to install the seals between the bearing cap and the block if the bearing cap wasn't completely torqued down.
