Order Ford 2000 Parts Online
Ford 2000
Ken in MO
02-07-2000 06:41:00
I just purchased a Ford 2000 4 cyl. 5 speed from an uncle and need to get some information on it. There is a model # on the block that reads CONN6015G with a 2 under that. Under the seat there is three lines that read NCA501, then B, then 2H15:. Where is the serial # on 2000? I believe it was made between '62 and '64. He had just had the hydraulics worked on last fall and now you have to bleed the pump every time you start it in order to get the lift to work. Any info you can provide would be greatly appreciated.
Dave Mischler
02-07-2000 09:39:36
 Re: Ford 2000 in reply to Ken in MO, 02-07-2000 06:41:00
Here is what you need to know for pre-1965 tractors:
Festus
02-07-2000 06:50:02
Try this link Ken. Festus
