Fuel Shut Off Valve for 641
Dutch
01-27-2000 09:00:04
I own a 641 Ford. My Shut off valve # 311292 is leaking when I open it. In the parts book is a
mention of an O ring .How do I fix this problem?
Mark B
01-27-2000 15:19:17
 Re: Fuel Shut Off Valve for 641 in reply to Dutch, 01-27-2000 09:00:04
Dutch- If it only leaks when you open it,and the valve bolts are tight (not too tight - they strip easy) It probably isn't the O ring. The packing in those valves goes bad, I've even seen brand new ones that will leak. Time for a new valve, in my opinion. Don't let it go too long - That valve is too close to the manifold, and I've heard many a good old Ford has met a fiery end due to fuel leaks.
Duke
01-27-2000 11:46:25
If you will look up under your tank you will see two bolts that hold the vavle in place. I had to remove the fuel line on mine (861) to let the valve come all the way out of the tank. Then your home free. Be sure and clean the screen while you have it out. Just in case your local ford dealer sells the whole valve for about 42.50. I had to replace mine a few months ago. Hope this helps.
