Order Ford 2600 Parts Online
Re: Ford 2600 diesel
Diesel doc
12-27-1999 18:09:42
Gary hey, Look at your mounting bolts on your Injector pump.Sound's to me like it has advanced the timing on you somewhere On The 2600 Dsl The Injector pump timing mark should be in line with your 0- mark on the pump flange, Check your fuel filter or the Tank valve Make sure you dont have any restricions, Causing ur engine to starve For fuel then it gets a gulp B4 it Stops turning, And better chances of Kicking Backward if the pump is advanced to much, The Starter syptoms sound like its firing against itself, Post back Let us all know what ya find out
