Order Ford 2600 Parts Online
Ford 2600 Puffing at the wrong end
Gary
12-21-1999 13:01:45
I Started my tractor this mornng Went to the house to get my gloves and coffie thermos.When i came to my tractor i thought it sounded funny but ignored it till i seen my tach was sitting on 0 .Fumes was coming out of my air intake what went wrong im afraid to restart it , Needless to say my 4610 went to the feilds this morning
JHEnt
12-25-1999 09:42:39
 Re: Ford 2600 Puffing at the wrong end in reply to Gary, 12-21-1999 13:01:45
Sounds like its running backwards. I never saw a diesel do this but I have seen more than one gas engine run this way. In these gas engines almost always there was carbon buildup. the tip of this carbon gets hot when running when you go to shut off the ignition the carbon is hot enough to ignite any gas in the engine. At some point while it is trying to stop turning the detonation of the gas pushes it back the other way and it may run like this for a couple of minutes.
Come to think of it I know a guy who did have a diesel going backwards. He was climbing an icy hill and at some point the drive wheels got enough traction to grab and the force stopped the engine and got it going backwards. He said it was blowing oil out the breather by the quarts. he quickly shut off the fuel.
Wow!
12-21-1999 14:37:37
Gary,
It would have been interesting to put it in gear to see which way it went! Is this a diesel and did you use starting fluid to start it?
I have heard of older diesels running backwards. I've never seen it but my dad used to warn me about it (I was under the impression that this was more likely to happen when shutting the tractor off by cutting the fuel supply then resuming fuel flow before the engine came to a dead stop). If in fact it was running backwards, I can't imagine it would be too good for it with the oil pump running backwards.
Gary
12-21-1999 19:13:02
 Re: Re: Ford 2600 Puffing at the wrong end in reply to Wow!, 12-21-1999 14:37:37
It's A Diesel, Nah i keep the starting fluid away from it, That's what i kinda thought it might have been running backward's
