Order Ford 4000 Parts Online
3 point hitch-4000
Mark
12-02-1999 19:33:05
Have a 4000 Industrial. I have been using it for the last couple years to do odds and ends and some fairly heavy bush hogging. It worked fine until this fall, when within a short period of time the 3 point hitch would not lift. It is totally dead now and I am unable to lift even the yoke. I can grab the yoke and manually lift it up and down, and the piston goes in and out but there is no hydraulic pressure behind it. Any ideas or suggestion? The implement/draft control lever does not seem to go completely "horizontal" or "up" and I has wondering if this could cause the problem.
Thanks for any help.
Grant
12-05-1999 08:07:58
 Re: 3 point hitch-4000 in reply to Mark, 12-02-1999 19:33:05
I have the same problem with my 4000 Industrial. I'm thinking about trying a Hyd. pump kit. I already had the lift cover seals replaced. It acts like it keeps loosing its prime. Over the past year I noticed the arms have been taking longer to come up when first lifting them. After they are up the first time they work great. Now they won't lift at all.
