Order Ford 4000 Parts Online
4000 hydraulics
Kevin
11-01-1999 19:51:22
Need help in removing the race from the hydraulic pump on a 1963/64 4000. Destroyed the seal to get at the race, but even after lots of pounding, haven't been able to budge it. Any suggestions? Heat it? Cool it? Weld it? I would appreciate any help you can provide. Thanks.
JHEnt
11-05-1999 17:55:39
 Re: 4000 hydraulics in reply to Kevin, 11-01-1999 19:51:22
If it is a trans mount pump like a 5000 then you should be sure you can even get the bearing separate. Ford/NH quit selling parts for pumps along time ago. You can get the whole pump from NH but you can buy new pumps from several catalog suppliers much cheaper.
Bern
11-01-1999 21:56:24
I'm assuming you're talking about a race for a tapered roller here. If so, weld a good bead all the way around it, obviously on the race itself. After it cools, it should darn near fall out on its own.
