Ford 871 Trans. Swap
Dan
08-28-1998 06:40:21
I'm looking for someone that has changed a SOS transmission for a manual trans. I would like some informatin on the process.
Thanks for the help.
Dan
Gary H.
08-28-1998 18:59:52
 Re: Ford 871 Trans. Swap in reply to Dan, 08-28-1998 06:40:21
: I'm looking for someone that has changed a SOS transmission for a manual trans. I would like some informatin on the process.
: Thanks for the help.
: Dan
It's been a while since I have done one and don't know how expensive it will be to do. You will need to get a 5-speed transmission{preferably one with live P.T.O. ,a flywheel, doubleclutch ass'y,backing plate on engine ,P.T.O. output shaft. Your coupler to the pinion shaft will probably have to be cut in half and welded together with a half from the other transmission. Other than that everything should work. Good Luck
