Position control device
Shawn in Ohio
02-07-2002 06:54:35
I just finished installing the position control device I bought from Stephen Gaunt. This is one fantastic accessory. It is very easy to install, and works exactly as he said it would. It gives you total position control and its made for a Ferguson tractor. And the quality of workmanship is excellent. It costs $70.00 and it was shipped to me in 4 days here in Ohio. Check this item out at the site below. Shawn
Ben Hogue
02-08-2002 09:04:10
 Re: position control device in reply to Shawn in Ohio, 02-07-2002 06:54:35
I'm really interested in getting a position control device for my TO-30. I wish someone would compare the one you've got with the Zane Thang. I've heard nothing but good news about both, but I don't know what the differences are. Prices are about equal.
Jim W
02-08-2002 14:19:24
 Re: Re: position control device in reply to Ben Hogue, 02-08-2002 09:04:10
Maybe Shawn can comment - it looks like the one from Australia is not very quick to remove. If I'm right the Zane Thang might be better for people who need switch back and forth between position control and draught control.
Jim W
Shawn
02-08-2002 15:55:11
 Re: Re: Re: position control device in reply to Jim W, 02-08-2002 14:19:24
Remove two bolts, take the collar off and the draft control is restored
Michael Williams
02-08-2002 10:09:55
I purchased the Zane Thang about a year ago for my TO30 and I couldn't be happier with it. It is performing exactly as the advertising said it would. It is VERY easy to install, and you make no modifications (cutting, drilling, etc.) to the tractor. It has worked great for me when I am bush hogging or leveling roads. I can't say enough good things about it. You set it and forget it!
RICK
02-07-2002 17:46:28
is this only for te tractors or will it fit to tractors also
Shawn in Ohio
02-07-2002 19:05:55
 Re: Re: position control device in reply to RICK, 02-07-2002 17:46:28
It will fit a TO too. I put it on my TO30 and it fits like a glove. Shawn
DavePA
02-08-2002 12:39:27
 Re: Re: Re: position control device in reply to Shawn in Ohio, 02-07-2002 19:05:55
How does one adjust the limits on the "Zane Thang" --and on the other position control? Which unit is more user friendly while in the pasture when changes are needed? thanks
Shawn in Ohio
02-08-2002 15:38:57
 Re: Re: Re: Re: position control device in reply to DavePA, 02-08-2002 12:39:27
When I installed mine, you set it once as per the instructions, then you're done it stays adjusted. You have to loosen the two bolts where the upper arms are attached and turn it one way or another to get your system dialed in after that then you retighten and thats it. This is Mr. Gaunt's control I'm talking about.
Sam
02-08-2002 15:41:57
 Re: Re: Re: Re: Re: position control device in reply to Shawn in Ohio, 02-08-2002 15:38:57
Hey how would you know about the other one. Its a big secret. At least the other guys you can see what it looks like at his website.
