TO 30 valve lash settings
Shawn
02-05-2002 16:32:51
I need to know the valve lash settings cold on a TO 30 gasoline engine.
Thanks,
Shawn
Pete@easttn
02-06-2002 05:00:20
 Re: TO 30 valve lash settings in reply to Shawn, 02-05-2002 16:32:51
My Ferguson shop manual advises .015 in. cold then run engine at fast idle for 20 minutes, then adjust to .013 in. while hot. In the old days at least for me early 60's DRAG CAR SOLID LIFT CAMSHAFTS WE WOULD JUST GO ABOUT 1 OR 2 THOUSANT'S TIGHTER WITH A COLD ENGINE AND THEN WITH HEAT EXPANISON THE ADJUSTMENT WOULD BE RIGHT ON. Also if anyone is interested my Ferguson shop manual is a reprint from orginal they can be purchased at Faxon Literature 1-800-458-2734
Ray,IN
02-06-2002 21:14:58
 Re: Re: TO 30 valve lash settings in reply to Pete@easttn, 02-06-2002 05:00:20
Pete, there is a descrepancy in either your or my owners manual. Mine says 0.013' cold, and nothing about a hot setting, though 0.015" will not be out enough for any harm. I bought my owners manual from the MF dealership nearby, it states "copyright 1951 by Harry Ferguson Inc"; back cover has "form no.z-3481-c" and 11/76-M.P.. I assume it's a Nov. 1976 reprint. Like I said, a loose setting will not harm anything but a tight setting will cause hard starting and possibly burn valves. These fine old machines are very forgiving or they would'nt still be running.
Ray,IN
02-05-2002 19:49:20
Setting is 0.013" cold for intake and exhaust. Loose settings will just rattle some with no damage. Tight settings will cause hard starting.
