Trans.
hydrolic oils
Jeff -Ohio
01-28-2002 10:23:17
I am new to the TE20 world and have this basic question. What type of oil is used in the TE20 transmision/PTO/Hydrolic case? My manual says 24 quarts but not of what type.
Also, What type of oil is used in the engine? Previous owner used a non-detergent 30 wt.
Thanks
Jeff
Ray,IN
01-28-2002 21:28:57
 Re: Trans. - hydrolic oils in reply to Jeff -Ohio, 01-28-2002 10:23:17
The trans/diff/hyd oil is 80/90W straight mineral oil. When you drain the system be sure to remove all 3 drain plugs, each will retain nearly 1/2 gal of oil in that section. My owners manual calls for non-detergent oil, 30W above 50F,20W below 50F, and 10W below 10F. Use the same oil in the air filter as the crankcase.
