Standard 87x92 gas engine
Phill
01-23-2002 08:24:27
Hi,
I have a Fordson Dexta with a Standard 87x92 4-cyl gas engine. A lot of engine parts are interchangeable with parts from the 87x92 engine used on some Ferguson FE35s, but I've been told the block casting is different. Does anyone out there have an 87x92 FE35 with that I could compare notes with?
manuel
01-25-2002 18:46:39
 Re: Standard 87x92 gas engine in reply to Phill, 01-23-2002 08:24:27
they had to cast the block to match up with the ford clutch & trans. so its only the rear thats different.
Duner Wi
01-23-2002 15:14:32
Your Ford Dextra petrol shares most internal engine parts with the MF35-MF135 87mm. Standard .
Sorry I can not help with the block casting but you may be able to widen your search to the MF35-135.
