TEA/D 20 engine data needed urgently!
Janne Riikonen
01-18-2002 01:32:04
Does anyone have the data concerning the TEA/D 20 Standard petrol/V.O. engine. I would need some values as stated below, since the local automotive bookstore seems to be SLOW with my workshop manual order, and my mechanic who's working on the fergie is waiting the info:
1.Crankshaft main bearing journal diameters (also undersizes) and the correct bearing clearance.
2. Crankshaft big-end bearing journal diameters (also undersizes) and bearing clearance.
3. Piston ring data (end-gap, groove measures)
4. Cylinder liner height measured from the block.
5. Piston-liner clearance
This info would be of great help!
Jack in NB Can
01-18-2002 06:47:33
 Re: TEA/D 20 engine data needed urgently! in reply to Janne Riikonen, 01-18-2002 01:32:04
Hello Janni -
The Vapormatic catalog lists the following info for the Standard series engines in the TEA/TED/TED20VO group:
Main Journal dia 62.97 - 62.979 mm
Crank pin (big end) dia 52.987 - 52.999
Float 0.043 - 0.1219
Small end bush reamed to 22.22 - 22.23
No bearing insert clearances listed.
Piston ring end gap 0.254 - 0.381
No groove measures
Overall cylinder liner height 171.450
Inside dia 85 (TEA20 = 80)
No OD., so no figure for liner/piston clearance.
Bearing and piston/liner clearance are generally similar for most gas engines in that size range, so if someone else doesn't have specific data for the Standard, you may be able to transfer.
You might also browse the BareCo website - they may have it, and possibly this site has data in the specs sections to the left.
BareCo:
Link
Hope this helps.
Jack
