Tool Box
FC
01-11-2002 06:47:25
I recently posted a message trying to identify a tool box I have over on the Ford N board. Apparently it is from a Ferguson instead. I will post the link to my previous post there and see if any of you guys have anything else to offer. Will this fit a TO 20, or just the TE 20? Thanks in advance for any help you guys can offer up.
Ivan
01-11-2002 16:27:12
 Re: Tool Box in reply to FC, 01-11-2002 06:47:25
I have a TE-20 with a box that looks like yours. Mine is mounted on the bracket that the battery sits on using the holes thru the back of the tool box.
Jim W
01-11-2002 12:00:40
FC,
Please send me an email if you are thinking of selling it, as I need one for my TEA20.
Thanks,
Jim W
Jim W
01-11-2002 11:17:38
That really looks like the ones on my TEA20s. The latch in particular is identical, but, as others have mentioned, it sure does look trapezoidal at the ends. Mine are mounted using the top two of the three holes that show in your picture, as well as one on the bottom, about in the centre.
Does yours have a hole in the bottom?
JW
FC
01-11-2002 15:49:52
 Re: Re: Tool Box in reply to Jim W, 01-11-2002 11:17:38
It has 3 holes in the bottom approx 1/4 inch in dia. I thought they were probably for drainage.
Phil (VA)
01-11-2002 09:19:14
I have a Ferguson tool box that is similar to the one you have. Mine has square, not trapezoidal, ends, so perhaps slightly different. At least yours looks in the pic like the ends are not square. Mine uses bracket to mount on left fender, and I think it is original.
FC
01-11-2002 09:42:00
 Re: Re: Tool Box in reply to Phil (VA), 01-11-2002 09:19:14
The picture angle makes the box look like it is not square. It is actually square or rectangular.
Phil (VA)
01-11-2002 11:59:19
 Re: Re: Re: Tool Box in reply to FC, 01-11-2002 09:42:00
OK. Likely same as mine, then. In that case, almost certainly a Ferguson item. I assume you do not have the bracket. If you want to sell it, you can contact me outside the discussion forum (via email).
FC
01-11-2002 15:53:36
 Re: Re: Re: Re: Tool Box in reply to Phil (VA), 01-11-2002 11:59:19
I tried to email you, but got returned undeliverable with the address you posted. I am thinking of selling the box, but have no idea of it's value. I believe I am going to list it on ebay, and that is why I am trying to determine what it fits.
