Starting the grey Ferguson
TH
01-09-2002 04:21:39
I've run across to information that says there was some special trick in starting the grey Fergies, such that most of the new owners didn't know how to start it unless someone told him how to do it. I know almost nothing about the grey Fergies, and I would want to know how these tractors were actually started? Thanks for the answers.
horsters
08-06-2004 15:45:20
 Re: Starting the grey Ferguson in reply to TH, 01-09-2002 04:21:39
Mine starts ok, but only runs 10 or 15 minutes and stops. Please help .
TH
01-10-2002 03:03:29
Thanks for answering. Did you mean that the starter works from the gear shifting lever? That must be the "trick" I had in mind. I quess that people unfamiliar with Fergusons turned the key and expected it to start or something like that. It would be difficult to find out on your own how it works if not told what to do.
Was that kind of starter used in all the grey models?
Phil (VA)
01-10-2002 09:22:51
 Re: Re: Starting the grey Ferguson in reply to TH, 01-10-2002 03:03:29
I think that type of starter was used in all the TO20s and TO30s ("grey"). I don't know about whether it was used in all the English built ones or not (more "grey"). I do have a TO30 that has an external starter pull lever, very similar to the Farmall arrangement, and it appears to have been factory, or dealer, installed; but this tractor has yellow paint on bottom layer (definitely not "grey") and was an industrial/commercial tractor in it's early life I'm certain, so maybe a municipality specified the change. The "S" is on the tranny cover on this tractor but it does not go to a starter button. However, that is a modified exception although professionally modified. I've seen shade tree mods too where the button was on the dash, etc., including one where the tractor was red and silver and represented as a TO35 (it was a TO20).
Boogity SW Ohio
01-10-2002 01:53:21
I start my TO-30 the same way. I was a little conceerned about how the starting would be after my overhaul this past summer but she starts better than ever now. I'm amazed - at 12 degrees F the other morning she fired right up instantly.
When you say "grey fergy" is there a particular model that you refering to?
Mark Hendershot
01-09-2002 09:38:22
The way I start my Ferguson TO-30 is to turn the gas on 1 1/4 turn, turn the key on, push the clutch down, pull the throtle control 1/3 of the way down, push the shifting lever to "S" (to engage starter) as soon as the engine turns I pull the choke lever for just a instant and let it snap back a few revolutions and it fires off, if not I snap the Choke again. Then I let it warm up a few seconds till smooth and slowly let out the clutch when It is real cold out side. Not much to it! I let it run for at least 5 mins. befor opperating. Mark H.
RichZ
01-10-2002 08:42:50
 Re: Re: Starting the grey Ferguson in reply to Mark Hendershot, 01-09-2002 09:38:22
Has my TO-20 been modified? I just either put it in neutral or depress the clutch, pull out the choke and turn the key, and it fires up. I always wondered what the "S" gear was for!
Rich
RICK
01-09-2002 18:46:27
i start mine the very same way as mark
bob m
01-09-2002 19:03:47
 Re: Re: Re: Starting the grey Ferguson in reply to RICK, 01-09-2002 18:46:27
I START MINE THE SAME AS MARK & RICK
