To30 air cleaner
RICK
01-05-2002 16:00:20
thanks for the info guys . now we need to figure out whos right .one guy says fill the outer part of the filter only. the other says i can fill that plus the small bowl with holes around the top of it that sets right in the center.who is right? it is a gas only engine.
Joe in NY
01-06-2002 10:25:23
 Re: to30 air cleaner in reply to RICK, 01-05-2002 16:00:20
Rick, Fill both bowls to the level shown by a ring on the outer bowl. Air is drawn into the filter and swirls the oil into the metal mesh filter. The air passing through the oil and filter media is what filters the air. When the motor is shut down oil will drain back into the bowls and equilize through the small weep holes between the inner and outer bowl. Check the articles archive to the left of the site and oil bath filters are explained in detail. Acually in is as fantastic system as evidenced by the age of these engines if ya keep'em clean.
Good luck,
Joe
Farmer John
01-05-2002 16:18:12
Fill both bowls.
