TO20 rattle or knock
Farmer(Ga)
12-29-2001 19:29:41
Hello all,I had a lowd rattle or knock in the engine.Since the fan was loose and quite a wobble in it i thought it was the water pump,i put on a new pump and the noise is still there.i am a little hard of hearing and cant tell where the noise is comming from.could it be the pully on front of cranksaft?It has a little wobble in it to.I'd be thankful for any surgestions or advice.Farmer
DunerWi
12-30-2001 04:13:42
 Re: TO20 rattle or knock in reply to Farmer(Ga), 12-29-2001 19:29:41
Timing gears may chatter rather than knock, especially at certain engine speeds. Make sure your front pully is tight. If your pully is loose just a bit the cam drive gear may knock on the woodruff key that drives the gear. A 2 by 2 piece of wood makes a pretty good device to hear engine noises with also.
Mark Hendershot
12-29-2001 21:27:59
Not to long ago someone had a knock and it turned out to be the timing gears. Take a plastic pipe or tube and put it on the timing cover and listen, then stick it in the oil fill tube and see which is louder. Then put in in the blow by tube. This way you might be able to isolate the noise between the timing gears, rocker arm assembly or rods/mains knock. You should be able to move the pipe or plastic hose around and figure out where the noise is the loudest. Mark H.
