TO-20 hyd.
mike mckechnie
12-27-2001 19:11:05
have 500psi. book says 1900-2300psi. will lift and hold back blade. lift is slow, what is the most common falt? any help would be great
Jim
12-27-2001 19:53:02
 Re: TO-20 hyd. in reply to mike mckechnie (g.p. or.), 12-27-2001 19:11:05
Will the lift hold the blade up after you turn engine off or hold the clutch down? If it leaks down fast it could be a gasket or piston rings in the lift cyl. or the valve that screws in the back of the pump that regulates the pressure. Any of these fixes are simple and relative inexpensive. When it is lifting slowly, is it smooth or is it jumpy? If it is jumpy on the way up, you have pump problems(valves or pistons leaking). Pump repairs can get expensive.
mike m
12-27-2001 22:19:37
 Re: Re: TO-20 hyd. in reply to Jim, 12-27-2001 19:53:02
jim will hold in up for 12+hr with motor off.
small amount of jump when lifting just a slight jerk ever so small. the psi. gage will remain at 500psi. untill i push the down lever. mike
