TO-35 Hydraulics
Dave
12-27-2001 13:11:33
My 35 has hydraulic problems. The transport(hydralever) lever will only raise my implement about 8 inches off the ground (it use to raise it all the way up). A Ford tractor mechanic looked at it twice, but he is not sure what the problem is. The Draft control levers appear to work properly. Any idea? Thanks.
Phil (VA)
12-27-2001 14:15:27
 Re: TO-35 Hydraulics in reply to Dave, 12-27-2001 13:11:33
Not sure about the 35, but the 30 has an external adjustment. The plate with four bolts that holds the lift lever (on the 30) has slots to allow it to slide to rear slightly and then re-tighten, and thus raises lift higher. I can't remember if 35 works this way or not without looking at tractor which is not available to me right now. On the 30, if it can't slide to rear any further, and all adjustment has been done, then the cam rod inside is worn and must be replaced. Again, 35 may be different. If your bolt holes are slotted, try it.
