Possitive Ground
Luft
12-24-2001 21:33:57
I just bought an old Fergie tractor that has been converted to 12 volt. The battery in it is hooked up as a normal negative ground. Would this be wrong ? should it be possitive ground? how would I tell it starts and runs okay. no smoke and fire yet>>
luft
12-25-2001 17:37:30
 Re: Possitive Ground in reply to Luft, 12-24-2001 21:33:57
Thanks for the help fellas
JW
12-25-2001 07:38:32
The later ones came with 12v negative ground as original; maybe you have one of those. (I have two 1952s and they both started life 12v neg ground.) Jim W
RWK in WI
12-25-2001 06:15:52
12 volt should / must be negative ground.
6 volt should be positive gound - usually but some have been mixed up or changed.
Rich Z
12-28-2001 12:11:46
 Re: Re: Possitive Ground in reply to RWK in WI, 12-25-2001 06:15:52
I just replaced the battery on my TO-20. I just automatically put the ground on the negative. It runs when the battery is first hooked up, but overnight, the battery discharges and is dead in the morning. Did I hook it up wrong?? Should the ground be at the positive. It's the original 6 volt.
