TO-20 Distributor
Clint (oh)
12-13-2001 13:44:07
I have a TO-20 and the distributor has quite a bit of end play in it. What would be the first step in rebuilding this to correct this problem
DunerWi
12-15-2001 05:44:09
 Re: TO-20 Distributor in reply to Clint (oh), 12-13-2001 13:44:07
Remove dist from engine. Determine if the end play is at the dist. drive gear end or is it by the advance mechanism. You probably have some of both . The drive gear end can be reduced by adding washers under the gear or in the dist. housing once you remove the gear. A close look at the advance mechanism end will reveal where the play is coming from.
