Learned something already
DW SAPP
12-09-2001 12:35:18
# TO-107500. She is a TO-30 instead of a 20. Give me some food for thought on her. Thanks
Phil (VA)
12-10-2001 14:41:29
 Re: learned something already in reply to DW SAPP, 12-09-2001 12:35:18
Does it start ok? If so, why change to 12 volts? If not, perhaps you can fix the problem instead of converting. This forum probably can help if you like.
Mark Hendershot
12-15-2001 20:20:02
 Re: Re: learned something already in reply to Phil (VA), 12-10-2001 14:41:29
Every one around here tells me change your TO-30 to 12 volt! I am staying with 6-volts it has worked for 50 years so far and starts just fine when cold with out any plug in heaters. Put new big cables on, tune/up, new battry and fan belt my 6 volt works just great your right don't change it out just fix it. Mark H.
