Surging idle
jd
12-08-2001 13:17:37
my to-30 starts right up, but then engine speed surges,rpm goes up then down quickly. what can i do
Ray,IN
12-08-2001 20:50:17
 Re: surging idle in reply to jd, 12-08-2001 13:17:37
I suspect the governor adjustments are wrong. This is a sensitive setting, you need to follow the owners manual instructions exactly. You may buy one from a MF dealer for around $30, the manual is quite detailed for normal maintence proceedures, it'll be the best money you've spent.
Drizler
12-26-2001 17:40:11
 Re: Re: surging idle in reply to Ray,IN, 12-08-2001 20:50:17
Before you do that make sure its getting gas. Mine has been a recurring hassle with the filter bowl and tank outlet. These things plug up easily and it isn't always apparent to look at. At present mine runs fine then starts surging unless the choke is full on. Probably something partially blocking the bowl filter somewhere. I solved that constant identical problem on my Farmall with a NEW BOWL. That was sound advice from someone with lots of previous experience. Make sure the gas is flowing freely from the carb bowl drain at the carb base and for more than a few seconds.
