TO-30 5 or 6 lug nuts on front wheels??
Mark Hendershot
12-02-2001 16:21:15
I have two axles one has 5 lug nuts and that is on a 1953 TO-30, the other axle assembly has 6 lug nuts for the front wheels and was from a older TO-30 when did they change lug paterns?? Mark H.
John
12-09-2001 16:48:30
 Re: TO-30 5 or 6 lug nuts on front wheels?? in reply to Mark Hendershot, 12-02-2001 16:21:15
Thay never came with five bolt hubs. Your tractor has wide front tires and to keep them from rubbing someone changed the hubs and rims.
Mark Hendershot
12-02-2001 17:22:56
The hub that has 5-lugs on it has a 3-inch Screw off bearing cap with a raised Y to knock (un-screw it)it off with. The rim size is 10 inch and was used in a orchard the back rims are 16.1 with 18.4 tires. Dose this help? Mark H.
DunerWi
12-02-2001 17:12:09
If your 5 bolt pattern is 5 1/2" dia. I will guess you have hubs from a 1949 or so Ford pickup.I also heard hubs from a 1949 or so Ford car will fit but am not quite so sure on that . Ford car was either 4 1/2" or 4/34" dia. circle.
Ken
12-02-2001 16:40:29
Mark-
I have a '53 TO30, and it has six lug nuts. The serial # is 118692.
Ken
