TO-35 Overhauled Still Knocking??
Help, Please
F. M. Mellott
12-01-2001 16:42:36
I'm working on a TO-35. I've rebuilt the engine, totally.
New sleeves, pistons, rod & main bearings (that crank mics 0.020" and that's what I used), new governor assembly, valve job, you name I did it.
But, the crazy thing still knocks like mad!! It does it at fast rpms under no load. Could it be the timimg gears?? I notice there seems to be an excessive amount of backlash in the oil pump drive gear but I can't think that all this noise is coming from that little bit of slop. Anyone else had this noise??....please help.
What I Found!!!! F. M. Mellott
12-06-2001 18:23:28
 Re: TO-35 Overhauled Still Knocking?? - Help, Please in reply to F. M. Mellott, 12-01-2001 16:42:36
I've worked on thetractor all week. Checking endplay, plastiguaging bearings, measuring crankshaft journals, etc.
Finally I found the timinng gears were severely worn in one spot. The teeth were worn to a point and causing a loud click. at high speeds this click sounded like a knock especially echoing in the cast oil pan and whit metal timing cover. I replaced the gears and she's quiet as a church mouse.
Thanks for all the responces.
Mark Hendershot
12-08-2001 12:22:41
 Re: Re: TO-35 Overhauled Still Knocking?? - Help, Please in reply to What I Found!!!! F. M. Mellott, 12-06-2001 18:23:28
Great! I was watching this post. I hope you did not do all the other work because of the timing gears. Mark H.
F. M. Mellott
12-09-2001 14:22:09
 Re: Re: Re: TO-35 Overhauled Still Knocking?? - Help, Please in reply to Mark Hendershot, 12-08-2001 12:22:41
No, the tractor was extremely tired and need the other work anyhow. I just hope this can help someone else avoid this problem.
Joe Ferguson
12-03-2001 09:16:14
Hi F.M.
From my experience if knocks with no load
and do not knock on load it is usually connecting
rod clearance too loose on crankshaft. Did you measure the crankshaft in order to have right connecting rod bearing size ?
If knocks under all conditions a screw or gasket piece or other &?% may falled in a cylinder accidentally when you reinstalled the head.
Just few tough
Good luck
Joe Ferguson
Dennis
12-03-2001 08:39:45
I'd suspect the crankshaft or camshaft end play.
ErnieD
12-04-2001 15:05:17
 Re: Re: TO-35 Overhauled Still Knocking?? - Help, Please in reply to Dennis, 12-03-2001 08:39:45
Did this engine have a seperate thrust washer/bearing?
dennis
12-05-2001 15:47:17
 Re: Re: Re: TO-35 Overhauled Still Knocking?? - Help, Please in reply to ErnieD, 12-04-2001 15:05:17
the t0-30 did. I'm guessing the 35 did too as they are very similar. There has to be some way to take up endplay, even if it's the rear main bearing edge that hits the crank flange. I just suggest that it might be a probable cause of the noise.
ErnieD
12-06-2001 16:36:05
 Re: Re: Re: Re: TO-35 Overhauled Still Knocking?? - Help, Please in reply to dennis, 12-05-2001 15:47:17
We had a to-30 that broke the thrust washer, found it in the oil pan. Ran it for a long time, but it was already loose and had poor or no oil pressure to begin with. It did have a very light rod knock at idle with no oil pressure. I do remember the crank would shift 1/8" when the clutch was depressed. I guess the end play was not very critical on a to 30, or oil pressure either.
