Strange Hub??????
Jone
11-30-2001 07:01:25
I`v noticed that my hub are wider on the middle, than in the ends, should it be like this?????
Thanks up front:-)
Mark Hendershot
11-30-2001 08:16:53
 Re: Strange Hub?????? in reply to Jone, 11-30-2001 07:01:25
Me too! I just bought a spare axle assembly and when I sat it next to my TO-30 front end I noticed that my hubs (caps over the bearings) had 3-raised rectangular parts on the cap (like knock offs) and were about 3 inches in dia. the front end I bought has bearing caps like you would see on a car. I do know it was a little older front end 1950? But the one on my tractor is Ferguson it is just different! Is this a up/grade or from a TO-35?? Don't know, anyone have a idea? Mark H.
Jone
11-30-2001 16:36:46
 Re: Re: Strange Hub?????? in reply to Mark Hendershot, 11-30-2001 08:16:53
Are we talking about the same thing here????
Im not that good i English..... ..
I mean the bowed Steel plate above the engine...., thats attached right benithe the Radiator and rests on the dash, it`s supposed to shield from the weather?
Im not Stupid, but dont know the english word for it, and didnt catch the connection with the speare axle.....
Mark Hendershot
11-30-2001 18:03:26
 Re: Re: Re: Strange Hub?????? in reply to Jone, 11-30-2001 16:36:46
Hello; A hub to me is the part that holds the wheel on. And I thought thats what you ment and I was asking about my hub too. I was not able to answer your question. I hoped some one could answer mine and yours too. I am not sure what part you mean. Do you mean the radiator shourd around the fan blade? that has a bowed shape and is used to help air go through the radiator. If not I do not know and maybe someone else dose. Mark H.
Mark Hendershot
11-30-2001 18:09:13
 Re: Re: Re: Re: Strange Hub?????? in reply to Mark Hendershot, 11-30-2001 18:03:26
I read it again and are you talking about the Hood? That is above the engine and petrol tank. If you are what kind of tractor do you have? Not sure I can help. Mark H.
Jone
12-01-2001 17:31:08
 Re: Re: Re: Re: Re: Strange Hub?????? in reply to Mark Hendershot, 11-30-2001 18:09:13
SORRY Mark H....
It was Too lait at night when i wrote this (This too 02.29 AM), and i really ment the HOOD.
I have A 1950 TEA Thats under restauration, and i thoght it was strange that the HOOD was wider at the middle, (about 2" wider) from the front and end..... should it really be like this Any ideas?????
Mark Hendershot
12-01-2001 19:17:29
 Re: Re: Re: Re: Re: Re: Strange Hub?????? in reply to Jone, 12-01-2001 17:31:08
I will haft to take a close look at my TO-30 hood tommorrow I belive they are the same except for the sides. But I bet there is someone out there that knows for sure. Mark H.
