PTO clutch add on?
Tim
11-29-2001 10:39:53
Hey guys I been scrolling through web pages looking at tractors and I have a question for you all. I forget where I read it but some where they were talking about the PTO on our ferggies. Our PTO is not a live PTO, it stops when tractor stops when you push in the clutch.It said something about it being unsafe cause the inertia of the implement could keep the tractor going forward. So it recommeded some sort of add on PTO clutch deal. I forget exactly what it was called.Any one know what it is called and have one installed?
Chuck (CA)
11-29-2001 10:58:20
 Re: PTO clutch add on? in reply to Tim, 11-29-2001 10:39:53
Sure Tim,
It's called and Over Running Coupler (commonly referred to as an ORC.) When you push the clutch in and stop the PTO from turning, the inertia is already happening with the implement; most prevalent with a mower. What happens next is the inertia begins to turn the pto, tranny, etc and YOU CAN"T STOP IT WITH THE BRAKES!! This is definately an E ticket ride when you're pointing towards a tree, fence, car, whatever.
The ORC is a ratcheting device that hooks on to the PTO and then to the implement. It allows itself to freewheel when you push in the clutch, allowing the PTO to stop and therefore you are able to stop. Good investment of 60 bucks. Be sure to get one that fits your PTO; probably 1 1/8" and has an output of 1 3/8". This way it becomes it's own adapter and you can eliminate your other one. For more in depth info on an ORC, check the archives on the Ford N board. Lot's of good info there, especially by Dell (WA).
Hope this helps.
Chuck (CA)
JW
11-30-2001 09:41:13
 Re: Re: PTO clutch add on? in reply to Chuck (CA), 11-29-2001 10:58:20
If you are in Canada you can get them for $79 Cdn. at Princess Auto. They have the 1 1/8" -> 1 3/8" version; as Chuck says, very handy.
Jim
Bob K
12-11-2001 07:31:36
 Re: Re: Re: PTO clutch add on? in reply to JW, 11-30-2001 09:41:13
This is a exceptional forum with so many "experts".
Regarding the ORC from Princess Auto - is it of high quality? I've seen a few other comments on this board about sloppiness and play with some ORCs and a couple of comments about the varied quality of some of the units on the market.
I have a 51 Fergie that I would like to use a rotary mower on but want to be sure I get a good ORC on it first.
Any suggestions what to look for as, to the inexperieinced, all of those metal things look pretty substantial until they start to twist, bend and distort.
Thanks
Chuck (CA) with more info
11-29-2001 12:03:24
Tim, click below for a really good site re: the ORC
Chuck
Tim
12-01-2001 03:58:53
 Re: Re: Re: PTO clutch add on? in reply to Chuck (CA) with more info, 11-29-2001 12:03:24
Thanks Chuck and JW,you are a great help. Thats exactly what I was looking for. That link was great, good info. I will definitely have to get one of those.Thats why this site is so great,there is always some one with the answer.
