Position control for the TO and TE Ferguson lifts
ZANE
10-02-1999 05:55:03
I don't know if any of you on the Ferguson page has learned about my recent invention and marketing of the ZANE THANG device that enables the 9N 2N and TO and TE Ferguson tractors to have position control just as the later tractors have.
I have a TO 20 that I have suffered with for the past 35 years with no position control and is why I originally came up with the design. It works great and is a breeze to install with just a couple of common hand tools.
Email me for particulars.
Installation of the position control.
Nothing has to be altered to install the attachment to allow you to have position control on the 9N 2N or TO 20 etc. It bolts onto the outside onto the existing components. It take only minutes to install with a few common hand tools. There are 4 or 5 bolts to install and a bit of adjustment to align things and you are in business. It will hold a boom pole in the position where you put it and will not drift either up or down until you move the control handle just as you normally would if it were an 8N with Henry�s position control.
I have one on my TO 20 and I just get excited every time I go out to use the tractor now. I have had this old girl for 34 years and always had to have chains and bars etc to use my hay rake or drawbar when pulling the trailer etc. Now all I have to do is move the original control handle up or down just as you would on an 8N and put the lift where you want it.
You take your hand off the control handle and the lift stays where it is put as long as the engine and pump is running. If you should want to use the draft control all you do is loosen two nuts and you have it back in the draft mode with no interference from the add on attachment.
Pete C (Aussie)
10-18-1999 22:45:03
 Re: Position control for the TO and TE Ferguson lifts in reply to ZANE, 10-02-1999 05:55:03
Sounds almost too good to be true. I think we folk "down under" would benefit from such a gizmo. (If the dollar doesn't fall too much) Could you please e-mail me information. TE20's are still popular here and we didn't change them to right hand drive!
Rege
10-05-1999 08:05:30
I'm interesting as well. Email me some info
Bob
10-03-1999 08:27:46
Zane Itoo have the same problem and would
like to how you resolved it.how can i contact you? I don't see any email address.
Ed W
10-15-1999 06:10:12
 Re: Re: Position control for the TO and TE Ferguson lifts in reply to Bob, 10-03-1999 08:27:46
Sounds interesting. Please send info. Ed
