TO 20 Hydraulic pump
Glenn K. WI.
11-25-2001 18:02:08
I 'm in need of some info. I've been having trouble with the hydraulics on my TO20. The bucket on my loader will not go down on occasion. I have cleaned out the fluid and case with diesel fuel and that worked for a short time, but the problem with the loader not going down is back and it also is lifting slowly now. I have removed the pump and cleaned it out, it was full of sludge , I noticed that the pistons are slightly scored and the pump housing has small cracks on the bottom of the holes where the valve chambers go into the housing. can it be rebuilt? if so , where can I get parts and gaskets at reasonable prices? Any help will be much appreciated . Thanks , Glenn
Drizler
11-29-2001 08:01:28
 Re: TO 20 Hydraulic pump in reply to Glenn K. WI., 11-25-2001 18:02:08
I simply took mine out and let the dealer look at it. They can do a pretty good assessment with a quick visual check, its a very simple pump and they have seen tons of em.
Ray,IN
11-25-2001 19:03:40
This arose within the last 3 weeks. Search for your problem, the guy found a source for pumps and posted it.
