To-30 front bushing
jd
11-25-2001 16:06:13
there is a bushing, up front,in front of crank pulley.pivot bushing?for steering arms? how do you change?where can i get one? how much? tractor has front loader on it also.
Shawn in Ohio
11-26-2001 07:46:20
 Re: to-30 front bushing in reply to jd, 11-25-2001 16:06:13
Hi, you are right there is a bushing in the front axle of your tractor. I just replaced mine its not hard to replace. It's located in the center of the pivot point. I found the easiest way to replace it is first take the hood off, then at the center of the axle there is a pin with a bolt that holds the pin in place. Remove the pin replace it if necessary, after you remove it then drive out whats left of the old bushing. My original bushing was steel, but the new one I got from Massey Ferguson is bronze. If you dealer tells you he doesn't have one Massey has a national parts locator so tell him to use that. Hope this helps. Shawn
