TO-30 Liffting Cap. and Tractor Catagory 1 or 2??
Mark Hendershot
11-20-2001 07:14:15
Hello; What is the lifting Capasity with good hydralics on the TO-30? Also what is the Tractors Catorgory Rating 1 or 2 ?? The 3 point hitch on the rear is it a 1 or 2 for buying things to work with. I am realy not sure about this part! THANKS! Mark H.
John, IN
11-20-2001 18:39:41
 Re: TO-30 Liffting Cap. and Tractor Catagory 1 or 2?? in reply to Mark Hendershot, 11-20-2001 07:14:15
Hay Mark, If you look to the left of this page you will see a Research & Info section. In that section there is 3-Point Specs.
Dennis
11-20-2001 13:02:26
I'vegot a modern backhoe on my 30. It weights in a nearly 1300lbs. The 3pt will lift it no problem. I have a wagner loader on the front. If I remove the bucket, I can lift the front of the tractor with one finger !!!!
Phil (VA)
11-20-2001 12:29:40
Cat 1 as Scott said. Mine lifts double row disk with no problem. It will lift front wheels off ground before it stops lifting, also as Scott said, so real restriction usually is not in the lift but how much weight is on front and whether you are on level ground or not. In other words, the front end weight is the weak link in the equation, normally.
Scott
11-20-2001 10:46:13
I'm not sure of the capacity. Mine carries a heavy old Massey Ferguson bushhog with no problem, I have to add weight to the frt to keep wheels on the ground. It is a category 1 hitch.
