Question for Jim W.
Red Rider
11-06-2001 19:32:10
Jim another question on TO20 external hydraulics. To plug the horzontal hydraulic passageway would you just run a tap in past the pressure pipe entrance and run a plug in just past that point?
Jim W
11-09-2001 06:26:16
 Re: Question for Jim W. in reply to Red Rider, 11-06-2001 19:32:10
If you mean to just remove the plug from the right side and tap that spot deeper, that's not what I mean at all. You can't end up with that spot closed off, as you need to take your output from the pump from there.
What I meant was to drill a hole into the passageway from above (say halfway between the plug on the right side and the centre), and tap that and plug it. It could be a bit of a challenge as it would have to completely plug the passageway and not leak, against the 2100 psi.
The trick will be to find the correct size plug. It will also be a good idea to not drill so deep as to go right through, as you'd end up with one more area to seal. I also don't know if there are bottoming taps for pipe threads; maybe someone with more plumbing experience can chime in here.
Bear in mind I have not tried this; it just should work in theory. I would like to hear from someone who has done it though.
