To-20 Rotor--Revisited
Clint (oh)
11-05-2001 17:08:02
A few weeks ago I posted a message regarding the problem I was having with my TO-20 breaking the rotor. After looking into this problem more I found that the distributor shaft has quite a bit of end play in it. If anyone could help me from here as in what will it take to correct this problem it would be greatly appreciated.
DunerWi
11-08-2001 05:22:53
 Re: To-20 Rotor--Revisited in reply to Clint (oh), 11-05-2001 17:08:02
How much end play do you have?
Maybe about .125 or a little more is normal.This end play is in the advance and is normal I believe. If you pull the dist. and look at the gear on the end it should have very little end play. If you completely dis-assemble the dist . you will find where the end play comes from. I just installed new bushings on the dist. shaft on mine so check the side ways movement while you heve it apart.
