TO-30 Exsaust UP/REAR Fire Reasons?
Mark Hendershot
11-02-2001 21:58:23
Hello; I read about a Ferguson that started a fire with its exsaust system! Has anybody had this happen and is it recomeded to mayby direct the exsaust up instead? What are the pros and cons? I live in a very dry area prone to fires and now I am concerned. Give me your point of view. Thanks, Mark H.
steve19438
11-04-2001 05:39:29
 Re: TO-30 Exsaust UP/REAR Fire Reasons? in reply to Mark Hendershot, 11-02-2001 21:58:23
one other thing, vertical stacks are great as long as you have no low branches to manuever under.
Phil Fenner
11-03-2001 11:02:20
If you put the exhaust up the noise will be "exhausting", so definitely wear ear protection if you don't already.
Phil F
steve19438
11-03-2001 07:56:25
common sense rules this issue. don't let the tractor sit in high grass. fires start with the exhaust pipe/muffler coming in contact with flammable materials.
Jone
11-03-2001 03:01:47
The TE`s were delivered with both options, and yes i have had this problem,our garage almost burnt down..... . Guess what i did.....
And i have herd that in australia you can only find fergusons with the exhaust going up.
Jone
11-03-2001 03:00:13
Mark Hendershot
11-03-2001 08:52:35
 Re: Re: TO-30 Exsaust UP/REAR Fire Reasons? in reply to Jone, 11-03-2001 03:00:13
Jone; Thanks! IT wasn't a dumb question and hearing about your fire tells me it happens. When I got my tractor I wanted to keep it original, since they went both ways I will re/route mine up! Eastern Washington is real dry in the summer and as far as common sense gos I wonder what would happen if the tractor stalled in tall grass with a hot exsaust system and you could not move it?? I guess it would look OK going up with a nice Rain Cap on it! Thanks for the comment! Mark H.
