Ridge at top of Cylinder TO-30
Mark Hendershot
10-29-2001 18:38:31
Is a ridge at the top of the cylinder about as thick as a finger nail alot of wear? The sleave is nice and smothe and no scores. The plugs were clean and all the same (tan) not much carbon on the pistons. I was just checking the engine out I got befor I installed it. Oil was clean no dirt or sludge in the pan.The valve train was also clean with no buildup. Just asking cause I have never worked on a tractor befor and I haven't got my manual yet but I want to start putting it back to gether! Will tork everything when I get my books! Thanks, Mark H.
Ray,IN
10-30-2001 19:31:36
 Re: Ridge at top of Cylinder TO-30 in reply to Mark Hendershot, 10-29-2001 18:38:31
The ridge is not excessive in my opinion unless the engine is blowing smoke from the crankcase breather tube. Tailpipe smoke is usually from worn valve guides. This is a wet sleeve engine and boring them excessivly tends to cause the engine to run hotter under heavy pulling. I would perform a compression check before making a decision to bore or resleeve. The level of cylinder pressure is not as important as all 6 reading being within a close range. I can't quote it now, I've forgotten what it is. Perhaps one of the guys will jump in here with more information for you.
Mark H.
10-30-2001 20:07:16
 Re: Re: Ridge at top of Cylinder TO-30 in reply to Ray,IN, 10-30-2001 19:31:36
Thanks Ray that make sence to me! Since the head is off I was going to take it to a machine shop I used for head work before and let them re-face the valves and check it out in case I over looked something! It sure is easy now then when it is back on! Thanks, Mark
Mark H.
11-01-2001 13:38:06
 Re: Re: Re: Ridge at top of Cylinder TO-30 in reply to Mark H., 10-30-2001 20:07:16
Thanks for all the help!! She is all back together now! Nice and tight and smoke free! I sure like Ferguson TO-30 Tractors!!! Mark H.
