TO 35 Hydraulic Pump shaft from crankshaft to pump
Gary D. in Wash
10-28-2001 22:37:43
I have a 1957 Ferguson TO 35 with a Massey Ferguson Model 99 front loader and an auxillary pump in the front driven by the crankshaft of the engine. The crank shaft is turning but the pump shaft isn't and there is no hydraulic pressure. I do not have a manual that shows how the hookup is accomplished. Is this a major repair or can it hopefully be simple? Any help will be appreciated. Thanks Gary
rod
10-29-2001 03:58:53
 Re: TO 35 Hydraulic Pump shaft from crankshaft to pump in reply to Gary D. in Washington, 10-28-2001 22:37:43
Probably the keyway in the shaft is broken off you have to take it apart to have a look.
regards
rod
Gary D
10-29-2001 21:59:49
 Re: Re: TO 35 Hydraulic Pump shaft from crankshaft to pump in reply to rod, 10-29-2001 03:58:53
Thanks Rod--Guess I will have to find a repair manual and see how to take it apart...
