Kigass
Gunnar B
10-22-2001 04:53:43
On my 54 TEF, the startingprocedure includes the use of a kigass pump during subzero conditions.
I've noticed the pump and container under the hood, but what is kigass? And furthermore, is it possible to obtain today, or can anyone suggest a substitute?
Regards Gunnar
Pete Tatham
10-24-2001 00:29:43
 Re: Kigass in reply to Gunnar B, 10-22-2001 04:53:43
Gunnar, Kigass is the name of the manufacturer of the cold starting aid. Under your bonnet, just behind the dash on the right hand side of the tractor you will see a small round tank with a screw top. This should be filled with diesel oil. On the dash, on the right hand side is the kigass plunger. Unscrew the plunger and pull out. This should charge the plunger with diesel from the small tank. Pull out the heater plug switch for about 15 to 20 seconds then push in the kigass plunger sharply. This atomises the diesel and injects it onto the hot plug in the inlet manifold. Operate the starter motor and she should start. Any queries, just e-mail me
Regards,
Pete.
Gunnar B
10-30-2001 06:20:13
 Re: Re: Kigass in reply to Pete Tatham, 10-24-2001 00:29:43
Thanks a lot Pete.
