TO 35 clutch activated switch
Jon Cline
10-18-2001 15:37:25
I have an old (at least 25-30 years) TO 35 that wouldn't turn over. I found a switch in the clutch housing that the clutch has to press to allow ignition system to be hot. I took wires off the switch and connected them, and the tractor fired up. As the switch is obviously a safety device, I would like to replace it but don't know how to identify it. Anybody know what it is called? Anybody know where to find parts?
Fred OH
10-22-2001 13:24:39
 Re: TO 35 clutch activated switch in reply to Jon Cline, 10-18-2001 15:37:25
Boy Jon, the longer you fish, the luckier you get. Try about 35 to 40 years old and you'll be about right. I think they made the TO-35 from 1955 to 1960 without looking over on the left. You're probably lucky with tractors too. I'll bet you put it back together and slid it down to that little "S" position and it started right up. It's half way between H and L. Seems like I had my first one off for similar reasons. Then I bought the book. L8R----Fred OH
Bob in CA
10-20-2001 22:02:34
I believe that the switch that you are refering to is the Starter Safety Switch that is activated by the High/Low shifter rail. The High/Low transmission must be in neutral in order for the switch to make contact.
