TO 30 Charging system
Chip Fontaine
10-14-2001 13:56:51
I have just purchased a To 30 and it has an alternator on it. The alternator is frozen and will not turn. Can I purchase a GM single wire alternator(having a built in regulator) and by-pass the existing regulator? This would also convert the tractor to 12 volts.
Phil (VA)
10-17-2001 06:59:35
 Re: TO 30 Charging system in reply to Chip Fontaine, 10-14-2001 13:56:51
If it already has an alternator, and not a generator, then it probably is 12 volts now. In that case, the short answer to your question is "yes."
Mike
10-15-2001 15:27:16
Chip,
Sounds like you are having a lot of trouble with that tractor. Perhaps you should cut your losses now and sell it to me.
Chip Fontaine
10-15-2001 15:44:55
 Re: Re: TO 30 Charging system in reply to Mike, 10-15-2001 15:27:16
No Problem Mike. It's yours for $1500.00.
