TO35 Carter UT carb problem
Jim McCary
10-12-2001 20:45:42
I'm double posting here and MF forum.
First, thanks to everyone who gave me pointers on my 9/14 post "Weird TO35 Problem" (espec. Big Dean!). The cam gear nut was loose and let cam walk backward. Now fixed and runs great except carb.
It's a Carter UT that leaks badly internally. Not enough to flood engine, but when not running I have to shut off sediment bowl. I can not find a rebuild kit locally for this carb. I have reset float three times, still no help. I&T manual says setting should be 11/64", but I am way beyond that now. Needle seals when I have it apart & blowing into inlet. No trash in fuel line because I have put in a new in-line filter past the sediment bowl + new hose.
Does anybody know where I can find a rebuild kit for this Carter UT? Any other suggestions?
Thanks,
Jim
Jim Duncan
10-13-2001 19:03:57
 Re: TO35 Carter UT carb problem in reply to Jim McCary, 10-12-2001 20:45:42
Jim: I have a Carter UT on my '56 TO-35, and have had similar experiences. You can get a rebuild kit for this carb. from a M.F. dealer in Sharon, PA. USA. The name is Watson's Equipment Inc. Their phone number is (724)- 346-6514, ask for Dave in the parts department. They are very knowlegable and helpful. They had a surprising number of parts on hand, reasonably priced and delivered (UPS) within a couple of days. If you can, be prepared with the carburator tag number. The tag is usually found under one of the carburator's top screws.
Jim McCary
10-13-2001 20:43:52
 Re: Re: TO35 Carter UT carb problem in reply to Jim Duncan, 10-13-2001 19:03:57
Thanks for the info. Unfortunately the tag is long gone. I&T manual lists 3 UT numbers, so I was hoping I could get in contact with a dealer that could ascertain if they were vastly different or not. Hopefully, if it is like most automotive kits, one kit covers all bases.
Thanks, Jim
