TE?-20 Identification...
Chris
10-09-2001 20:32:25
I have recently become the proud owner of an unidentified Grey Fergie... To the best of my knowledge it is a TE?-20 of some description, however the serial number plate is missing...:(
The engine number from this beast is SC13045E, and it has a Lucas ignition system. Also it is 12 Volt, but I am unsure if this is original or not...
The rear section of the transmission has 20111 cast into it in raised letters just in front of the dip stick location.
Any help to identify this machine would be greatly appreciated...
Thanks, Chris...
Manuel
10-13-2001 16:06:47
 Re: TE?-20 Identification... in reply to Chris, 10-09-2001 20:32:25
Chris,
For the TE fergy, the Continental motor was used from 1946-8. The Standard motor was used for the rest of the grey fergies life. till about 1956-7 I think. Early greys had the vertical oil filter, later they put it on an angle. 12v system started about 1952-3. If u find the serial let me know & I will give u the year.
rod
10-10-2001 04:42:41
sounds like a TEA 20? is oil filter on left side of engine and slightly tilted down? If so probably TEA 20 made in Coventry England with Standard Vanguard engine on carb might be Zenith 24T2 stamped. regards
rod
Chris
10-10-2001 23:49:35
 Re: Re: TE?-20 Identification... in reply to rod, 10-10-2001 04:42:41
> sounds like a TEA 20? is oil filter on left > side of engine and slightly tilted down?
Yes, it is...
> with Standard Vanguard engine on carb might be > Zenith 24T2 stamped.
Yes the Carb. has Zenith and 24T-2 stamped into it...
Is it possible to find out the year of manufacture of this beast? And/or which size engine it has?
Thanks in advance... Chris
